Jimna 354
   / Jimna 354 #1
Rob Larson
Jimna 354
My Jimna 354 Turns over But will not start. Fuel to injection pump but no fuel at injectors
   / Jimna 354 #2
Have you checked the oil level in the injection pump? Sounds like it is air bound, did you run out of fuel? You'll need to loosen the hard lines at the injectors and crank it over with the throttle set to low idle. As fuel begins to squirt from the lines, tighten the line nut after all the air bubbles are gone. This is all based on the assumption that you don't have collapsed flexible fuel lines.
   / Jimna 354 #3
Sounds like a stuck fuel cut off rack.
Have you cracked a connection at the injector to make sure the pump is or is not pushing fuel?
   / Jimna 354 #4
If you ran out of fuel you have to prime the fuel pump. On the pump there is a small hand pump. You unscrew the top to release the plunger, pump it until you hear fuel running back into the fuel tank.
IH 810-10 Pick Up Head (A50514)
IH 810-10 Pick Up...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2016 FREIGHTLINER 2500 SPRINTER VAN (A51222)
2016 FREIGHTLINER...
2016 John Deere 410E 40 Ton Articulated Off-Road Dump Truck (A50322)
2016 John Deere...
