My apologies then for the red herring. A TPH has two sets of lift arms, upper and lower. You didn't specify, I guessed wrong.dh0765 said:Greg G, it is leaking where the part #30 attaches in the diagram you sent. I replaced the seal previously with a 42x62x10 seal.
Ranch_Hand_Supp said:I am going to assume the bushing/bushings went bad and damaged the seal.
To get a good look at the lift shaft for possible wear .. it will have to be removed and that means removing the lift box. Not a real big job... just heavy.
Ronald
Ranch Hand Supply.
dh0765 said:Ronald, any advice/procedures for doing this? I will probably tackle it this weekend.
Thanks.
