Jinma 224 Tachometer
   / Jinma 224 Tachometer #11
Well my point was that the tachs on JM Parts & My website are not aftermarket they are OEM
Hmmm, ok - I'm definitely behind the power curve on that one then. Cuz neither of my JM254s (individual gauges) had a tach that looked like that, and I'm sure (at the time) that a replacement was nowhere near $210. Perhaps Rural King spec'd a more basic tach on the ones they imported. But considering that's more than half the cost of an entire cluster panel, the justification for that kind of price tag escapes me.
//greg//
   / Jinma 224 Tachometer #12
//greg//
You are correct about the price,but you referenced them for the source for the replacement.Not sure what yours had, when we started selling these tractors in 2002 they had this tach.If there is a different one from earlier models I would like to see what they looked like,if anyone has one please send me a pic
Tommy
Affordable Tractor Sales
   / Jinma 224 Tachometer #13
Do you know the wire pinouts for the back of it?. Believe I now have 4 connections. Sound right? With the hour meter would there be more?
Yes, more connection points if it had an integral hour meter. You probably only need 3 of the 4, unless there's actually a light bulb. That's where the common red wire would go, if the gauges had bulbs that is. The other three may be marked as S/G/K. S & G connect to the sending unit down at the bell housing. K is the 12v source, tapped into one of the rear lighting wires I think.
//greg//
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
