Jinma 254 - General Operational Question
   / Jinma 254 - General Operational Question #21
You cannot increase pressure, as that is a factor of the cone/cup spring inside the clutch assembly. You can only adjust if the pressure is applied or not, but not how much.
I don't think the gap at A is important. All it does is adjust the gap at B, which IS important. That adjustment along with the springs in that linkage(at gap A) maintaining the gap at B. If you are not touching at B you are getting as much force as you are going to get. If when you opened the access cover you didn't have any gap at B, that was your problem as the main pressure plate was "hanging" on those fingers/levers preventing full pressure from being applied. If you did have a gap at B when you first got in there, your clutch friction disc is probably shot. And of course as the disc wears down, the spring extends more and more lessening the available pressure to be applied so once they start slipping they usually fail completely shortly after that...
When you step on the pedal, the bearing slides forward pushing on the fingers at "B". That gap is your clutch pedal freetravel. When pressed upon, the fingers/levers lift the main plate at 3 locations(A) compressing it's cone spring and releasing the main clutch disc. As that main plate lifts, it in turn lifts the PTO plate releasing the PTO clutch disc. It lifts the PTO plate at those 3 adjuster nuts located between the lever/finger adjusters(at A) as you go around the clutch assembly. One way to gauge how much your main clutch disc is worn is to look at the gap between the main and PTO plates on those other adjusters. As the main disc wears the gap between the main and PTO plates decreases as there is less and less disc material to hold them apart.
Looking at your pics, it does not appear that you have a lot of gap between the main and PTO pressure plates...
Here is a link to Johns Jinma website(great jinma 254/284 resource) and a clutch adjust procedure. He was not adjusting the main clutch in this procedure, but the relationship between main and PTO, but the pics are very good. On the second to last pic, note the gap between the main and PTO pressure plates at those alternate/PTO adjuster nuts It is WAY larger than your appears to be JMClutchAdj
Thanks for all the responses guys. I've learned a lot. Replacing the clutch wasn't the answer I was hoping for, but looks like that's the right answer. Time to start reading about splitting....
   / Jinma 254 - General Operational Question #23
Duplicate :(
   / Jinma 254 - General Operational Question #24
OK, forum was acting wierd with me as well, seems to be working now...
   / Jinma 254 - General Operational Question #25
Years ago when I got my Nortrac Jinma 254 delivered from Northern Tool, I had a similar issue. The tractor was delivered by a truck driver who did not know much about the tractor so I didn't get a "Welcome to Tractor Ownership" lesson like I thought I would. I had to figure everything out. I was having a similar issue that my tractor would not move under idle speed and I had to give it some gas to go.... Took me about a day (when I finally read the manual that came with it) before I realized that there was a "parking break" lever engaging the foot brake. I was hoping as I read thru the post that it would be some type of "oh my gosh" situation like that... Good luck. (P.S... your break isn't set is it???) :)
The brake is not set, but I should check to make sure they're properly adjusted. They might possibly be slightly engaged?
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55314)
2025 Wacker Neuson...
17201 (A55852)
17201 (A55852)
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
Gravely 42in Zero Turn Mower (A55851)
Gravely 42in Zero...
2003 FORD F350 XLT SUPER DUTY CREW CAB TRUCK (A57192)
2003 FORD F350 XLT...
