Oil & Fuel Jinma 254 Won't Start After Oil Change
   / Jinma 254 Won't Start After Oil Change #21
Very good points, Ron! If the linkage is there in the valve train, it can't be too difficult to rig either a lever or a cable to activate it and save a lot of wear and tear on your engine. Certainly don't have anything to lose by trying.
   / Jinma 254 Won't Start After Oil Change #22
Just to close the loop, the winner is ..... oil in the #2 cylinder! Removing the glow plugs is definitely the way to go, it's a lot easier than messing with the injectors. Once I got them out I cranked it over, it blew a geyser of oil out #2. I let it sit for a couple of minutes and did it again, lo and behold another geyser of oil shot out. Cleaned off the glow plug and reassembled, and it fired right up on the first try. I'm happy again.
On a side note, the engine has a bracket for a "pressure reduction mechanism," and the lever and return spring is there. When you push it, though, it doesn't feel like it's actuating anything (and it certainly didn't help me clear the oil). I wonder if the rest of the mechanism isn't installed. It's listed in the parts diagram for the engine.
THIS ... Now I just need to devise a way to keep this from happening the next time I change the oil. ... Has anyone heard of any other ideas to prevent this other than pouring slowly???
Curious because I need to change the oil on my Jinma 284.
   / Jinma 254 Won't Start After Oil Change #23
I have simply made it a habit to always use a funnel since that only allows me to pour at a slower rate.
   / Jinma 254 Won't Start After Oil Change #24
Been awhile but I wanted to say Thanks erj ... The funnel did the trick. Next up is the fuel filter.
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50323)
2016 Big Tex 14ft...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50322)
2013 Vermeer V800...
2011 BMW X5 xDrive35i AWD SUV (A50324)
2011 BMW X5...
Deere 333G (A50120)
Deere 333G (A50120)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
