Jinma starting
   / Jinma starting
The cardboard was to hold a little devcon in place untill it hardened, also had to use a metric bolt in one of the holes as I couldn't find the right length metric stud even from dealer.
   / Jinma starting #12
I have just repaired a Siromer (Jinma) 204S with electrical problem ... after 3 days of tracing and checking all the wires and connection i found the problem under the console. there is a power going from the 30 amp fuse to the amp meter and then from the amp meter to the switch. these 2 wires have a connection... this is where my problem was sometime it would start sometime not... Check this connection and see if it is ok ... Good luck...
   / Jinma starting
Any more problem I will check that
   / Jinma starting
So far starting ok
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
New/Unused 4ft Bush Hog BH114 Rotary Cutter (A51573)
New/Unused 4ft...
PALLET OF 6' X 12' SITE FENCE (A51248)
PALLET OF 6' X 12'...
Under Body Toolbox (A51573)
Under Body Toolbox...
2017 TAKEUCHI TB240 EXCAVATOR (A51246)
2017 TAKEUCHI...
