John Deere 2010 sediment bulb repalcement
   / John Deere 2010 sediment bulb repalcement #1
Farwell
Veteran Member
Farwell, Michigan
JD 2010
I am having problems with my sediment bulb leaking and haven't been able to get it to stop. Any one know if there is a replacement for the sediment bulb. I was thinking about an in line fuel filter as a replacement.
   / John Deere 2010 sediment bulb repalcement #2
Isn't there a cork washer that seals to prevent leakage? Seems I remember getting good results when I replace it, as the old one was a bit brittle and hard.
The glass bowl itself should be okay.
   / John Deere 2010 sediment bulb repalcement #3
If not a cork washer.. then a neophrene gasket.. either should work. An in-line fuel filter is not the same beast as a sediment bowl/water seperator..e tc.
Soundguy
I checked the cork and it seemed to be soft enough. The cork was the first avenue that I was going to take but the inline filter came to mind. After thinking about over night it dawned on me that a fuel system that has a filter in it probably has pressure in it, where my tractor probably works on a vacuum. Thanks guys, I am going to hit the Napa parts store today for a gasket.
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
2014 FREIGHTLINER CASCADIA DAY CAB (A51219)
2014 FREIGHTLINER...
2008 FORD F-650 (A50854)
2008 FORD F-650...
2021 POLARIS RANGER 4x4 UTV (A51222)
2021 POLARIS...
