John Deere 2120 Brake Concern
   / John Deere 2120 Brake Concern #11
Ditto I think valve(key 3) is the problem also. AL70242 Pneumatic Control Valve 69.10 USD 0
   / John Deere 2120 Brake Concern #12
bigblock76;4776341 Or is it the seal #14 that needs changing?[/QUOTE said:
O-ring(key 14) only seals plug(key 13). If plug isn't leaking o-ring is fine.
Should I start with this part then? AL70242 Pneumatic Control Valve 69.10 USD
   / John Deere 2120 Brake Concern #14
Order 2xno 2 and 2x no3...remove no 2 and strip valve....clean all . When assemble make sure no 3 do not touch piston and do not use silicon on gasket...there is a small hole in the gearbox casing allowing oil to fill mastersilinder...after assembling remember to adj the pedals with the 3/8 bolts on top...all pedalfreetravel gone plus 1/3 turn tighter...do not try to adj pedals equal ! Lock 3/8 bolts with there nuts !
   / John Deere 2120 Brake Concern #15
Ditto what DLTTrekkers stated
I致e ordered 2 equalizing valves. Waiting for them to arrive.
Is there a way to test the brake linings without taking the axle apart to see how much lining is left?
   / John Deere 2120 Brake Concern #17
No way to check brake lining thickness other than removing final drives.
Is it worth doing giving age of the tractor and unknown history prior to me owning it? Given the horror stories I've heard about the metal getting everywhere and messing up the pump. Is it hard to service other than needing to take an axle off once your inside?
   / John Deere 2120 Brake Concern #19
Brake linings are relatively easy to R&R once axle housings are removed. IMHO installing cow magnets in the bottom of older JD tractor trans case of this era is a good idea to help limit hyd components exposure to metal fines.
2021 Krone ECTC 400 (A50123)
2021 Krone ECTC...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2025 Mower King SSRC (A50123)
2025 Mower King...
2011 Deere 650J (Camilla, GA) (A50123)
2011 Deere 650J...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
