john deere 2520 hydraulics
   / john deere 2520 hydraulics #1
a2520
moncton,NB
john deere 2520 hst
Hi
bought my second john deere went from 2305 to a 2520 because of my ex. hmmm thanx i think i forgot to thank her. i have pallet forks, waiting on a 54" box blade thru everything attachments. Plan on making a a tnt for the 3 point hitch i picked up one cylinder already.have a mechanical diverter valve now but plan on a 2 or 3 spool valve with power beyond port for the back. Also considering a bx70 woods backhoe, i know i have to make a beefed up hitch support and a subframe. Had an imatch i plan on another or a speedco quick hitch. Bought a 35 amp alt (not impressed with john deere and there 20 amp and there 3 point hitch rubbing the tires ,shame on their ignorance of knowing the difference). To thinking the buyers r stupid well here"s ur sign ur lucky we see a good product with inefficiencies. I must thank everyone for their help on hydraulics open and closed and power beyond. my only question is what size of lines to maintain 10.5 gpm? yes i realize size of connections restrict with size to so minimal size for the gpm ?
any help will be appreciated. also being an aircraft mechanic for 16 years and then aircraft structures for 5 more. yes i do understand how things work and i appreciate the advice on this site from its members of what i've read already and pictures have helped a lot. Thanx to all
   / john deere 2520 hydraulics #2
Welcome to TBN. You might want to post your question in the John Deer specific area. There is a huge knowledge base here. Pictures too. We love pictures. Take care. -robert
Posted with iPad 2 iOS v5.1 -TBN v1.5.16
   / john deere 2520 hydraulics #3
Welcome from Oklahoma.
Ken
   / john deere 2520 hydraulics #5
Welcome to the forum.
   / john deere 2520 hydraulics #6
You only need to size the lines for 5.0 GPM, the other 5 is dedicated to the steering. 3/8" lines are fine. The system is open center. JD did change the lower 3PH arms in the later models.
   / john deere 2520 hydraulics #7
Welcome to TBN :)
I moved your thread to the John Deere Owning/Operating forum.
Thanx Kennyd i knew there was 2 hydraulic pumps on the 2520 didnt know they both put out the same. They did come out with 40amp alt and new arms yes and it should be covered by jd coz both r a problem was my point.
thank you Briana03
   / john deere 2520 hydraulics #10
A lot of dealers/JD did cover/replace the 3PH arms when the original owners complained there are MANY threads here about that.
Why should they "cover" a alternator? I have a 20 amp on mine, with 4 worklights and other goodies and have never needed more. Only if you have a cab maybe would you require more that 20 amps.
well its the voltage regulator then likely the other owner replaced the battery once. If i use lights its dead the next time actually i have to charge it every 8 starts or so right now. No heat in the garage, plus after my back is fused then i'll be able to install the 35 amp anyway. not sure about a cab yet but ill have the power there anyway.
CAT 930M (A58214)
CAT 930M (A58214)
2012 GENIE Z45/25J ELECTRIC BOOM LIFT (A60429)
2012 GENIE Z45/25J...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2006 Nissan Frontier Ext. Cab Pickup Truck (A59230)
2006 Nissan...
