Rear Finish Mower John Deere 272 Finish Mower
   / John Deere 272 Finish Mower #11
The mower leaves intermittent grass uncut. The cut is not smooth at all. The grass is field grass planted two years ago. I run the tractor at full PTO speed.
Thanks.
I suppose you've checked to make sure the belts are properly adjusted so they don't slip? Also, do you cut in the mornings when there's a lot of dew on the grass, or later in the day when it's usually drier? Is it leaving big clumps of cut grass as you mow?
   / John Deere 272 Finish Mower #12
My mower deck will leave a lot of bahia stems sticking up if they are 12" tall to begin with. The bermuda grass cuts great if it is not dried out.
   / John Deere 272 Finish Mower #13
Have you tried mowing "normal" height grass with it? Is it uneven then also? That would tell you if its the mower or if it's the tall grass that's the problem.
I know you said you've tried cutting 6" tall grass but that's pretty tall still for a finish mower imo.
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2006 VOLVO L110E (A52472)
2006 VOLVO L110E...
2016 Ford Explorer...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
EZ-GO D499 Electric Golf Cart (A51694)
EZ-GO D499...
