john deere 3020 info needed
   / john deere 3020 info needed
Tx Jim said:
Side console built '69-'72. Main advantages were 12V electrical system instead of 24V and 3pt/scv controls beside seat instead of LH side of steering wheel. Also SCV(rear hyd outlets) had no hyd lines running under floorboard to spring hyd oil leaks.
Power assist steering has mechanical linkages(drag link) coupled with hyd pressure.
Hydrostatic steering oil has oil only to control frt wheels(no mechanical linkage between steering wheel & frt axle)
Is there a chassis size difference between the 2520 and the 3020?
   / john deere 3020 info needed #12
The 3020 always seemed to be a bigger machine - IIRC. When I double-checked my memory.... here: TractorData.com John Deere 2520 tractor information
There was a difference of about 500lbs.
'Course the tires are bigger on the 3020 and that makes the overall tractor seem larger.
AKfish
   / john deere 3020 info needed #13
The main difference in the frames is the 2520 uses a totally different clutch housing(part # AR38574) due to also using a totally different engine(Dubuque 300 series). AKfish is correct as 34" & other sizes or rear tires weren't an option on 2520's.
Ok thanks a ton!
Would anybody be able to tell me the difference between the John Deere 4020 and the 4010? Besides the horsepower.
   / john deere 3020 info needed #15
Jared - I don't have the answer specifically to your question but first understand the Series. You are comparing the "10" Series to the "20" Series which is one of the important distinctions in understanding the numbering lines. You can get current Series info on the JD website. Also remember that tractors do not have titles like vehicles; there are many scams and many stolen tractors which is sad but a reality so be very careful in purchasing a tractor from a private party.
   / john deere 3020 info needed #16
Ok thanks a ton!
There's a few differences between early('64-'68) 4020's & 4010's. 4020 could be equipped with Powershift trans which was not available on 4010's. 4010's had rear pto shaft that bolted on and also changed pto speeds that had a history of giving some problems whereas 4020's pto stub shaft was held in place with a snap ring. Late model('69-'72) 4020's were 12V instead 24V elect systems and had hyd controls relocated beside seat(side console) instead of LH side of dash.
WITTIG VACUUM PUMP (A47001)
WITTIG VACUUM PUMP...
1979 Trail 40 ft Hopper Bottom Grain Trailer - Dual Grain Doors and Leaf Spring Suspension (A46884)
1979 Trail 40 ft...
Spudnik 910 Dirt Eliminator (A47369)
Spudnik 910 Dirt...
2013 Ford Focus SE Hatchback (A46684)
2013 Ford Focus SE...
Lockwood 36” Screen Sizer (A47369)
Lockwood 36”...
78in Kivel Bucket (A47809)
78in Kivel Bucket...
