John Deere 318 Starter Won't Crank
/ John Deere 318 Starter Won't Crank #1
Tjaltz
Gaffney, South Carolina
Kubota B3200, L6060
Hello All:
I have a 1989 John Deere 318 with an Onan P218G engine and a John Deere AM107421 voltage boost relay installed. The tractor has been starting fine for years. Today when I turned the key, nothing. No starter response at all. Have geed battery voltage, even tried a booster, no difference. Two lights on dashboard are lit, shift is firmly in neutral, parking brake is set, I'm sitting on the seat, turn the key and nothing. Possible the hard starting relay failed? Bad safety switch on the seat or shift? Is there a way to bypass the safety circuit to test it? Any help would be greatly appreciated.
/ John Deere 318 Starter Won't Crank #2
Sounds like you need to use a voltmeter to check for voltage at the starter relay while the key is in the start position. You can also use it to check the seat and ignition switch.
PS. What is a "ratchet rack"? (listed in your sig...)
/ John Deere 318 Starter Won't Crank #3
I hope that you get good advice on your problem as I have exactly the same problem on my 2320. What a disappointment this morning. I'm out there at 6AM and the tractor is dead. The only signs of life are four indicator lights and a buzzing behind the dashboard.
I'd like to add 19-32 degrees, battery is at 12.77v and I checked the five fuses visually and electrically.
Maybe this is a good time to buy the service and parts manuals.
/ John Deere 318 Starter Won't Crank #4
Have you cleaned your battery terminals?
/ John Deere 318 Starter Won't Crank #5
Betcha $10 you need a new battery...The ones JD have been using the last few years are junk. Do a search for "battery" In the JD forum to see what I mean.
Actually that was a typo. Suppose to be ratchet rake. Teeth that clamp onto th bucket with ratchets. ratchetrake.com
Mine has a new battery, the terminals are clean and I alsi tried a 300 amp battery booster clamped to the battery terminal cables. Nothing.
/ John Deere 318 Starter Won't Crank #8
The starter on my 1990 318 died this summer. There's an exact replacement (Mitsubishi?) the dealer found that was less than the JD replacement part. When mine died, it had been acting up for a year or two. Like Kennyd said, I'd check the voltage at the starter (both battery and wire from the switch/relay) 1st. Even when mine was dead, it made a clicking noise and dragged the volts down a bit (like the solenoid was there, but the contacts were shot). No volts = start tracking down the safety interlocks.
The new starter spins things so fast that it takes longer to start than it used to with the original starter running slow. I probably just need to re-learn gas and choke points and operation.
Pete
/ John Deere 318 Starter Won't Crank #9
My 318 did the same thing. It was the Neutral Safety switch. I noticed I had to occasionally "slap" it into neutral before the starter would engage.
Could also be the Seat switch(easy to jumper out) or the PTO switch engaged.
The guys at Adams Power Equipment were pretty helpful but that was 6 years ago. Good Luck.
/ John Deere 318 Starter Won't Crank #10
Sorry I did not want to sound elementary- I have seen some wierd stuff with lightly crusted terminals. Sounds like a safety switch or starting solenoid??
Good luck keep us posted!
/ John Deere 318 Starter Won't Crank #11
A couple of simple things to check, make sure your PTO switch is in the off position, that would be down. And make sure your hydro lever (red knob) is in neutral way over to the left, hold while you turn the key to be sure it is contacting the micro switch. Also make sure the seat safety switch is working correctly and double check all of the wiring that you have added. It's got to be something simple, the hard part is finding it.
Ken
/ John Deere 318 Starter Won't Crank #12
DO YOU HAVE ANY LIGHTS WHEN YOU TURN THE KEY ON ? THERE ARE FUSE ON THE SIDE BY THE BATTERY, IHAD ABURNT OUT FUSE CONNECTOR. MY STARTER HAD THE SOLNOID ON THE STARTER.
/ John Deere 318 Starter Won't Crank #13
My cranking problem was solved by replacing the battery. It was a two year old JD with 110 hours on it.
No load it measured 12.77 volts but apparently it had an internal problem that caused the voltage to drop when a load was put on it.
I kick myself for not trying to jump start the battery even though it appeared to be fine. Or not pulling it out and bringing it to an auto shop for testing.
When told of the solution, all of my friends jumped on the 'I told you so' bandwagon. It's easy to diagnose a problem when you know the solution.
/ John Deere 318 Starter Won't Crank #14
At least it's fixed, that's the main thing.
Midwestern Industries MEV Screen Model MEV 5X10-2 (A61306)
Midwestern...
(1) 36"X7' ADS DRAINAGE PIPE (A60432)
(1) 36"X7' ADS...
CASE 586H ROUGH TERRAIN FORKLIFT (A60429)
CASE 586H ROUGH...
SWICT 72" SKID STEER BUCKET (A60430)
SWICT 72" SKID...
DEUTZ MARATHON...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
