CowboyDoc,
<font color=blue>Originally, like I said, they had in a very strong limited slip unit in the front end. Now it's a weaker unit. The reason being that you can't have both worlds. You either have to the very low limited slip so as not to scuff the tires or you crank it up and scuff the turf.</font color=blue>
I appreciate your comments, and am glad you have access to some apparently reliable sources. /w3tcompact/icons/smile.gif
I am left with a question about "emphasis", ...and the resulting impression.
If the situation you describe("either/or") is what design engineers face, re. MFWD axles, then I assume it is the same for K.and NH. engineers as well.
I do not hear anyone saying Kubota(for example) has a front axle that they have made "weaker" than they might have, so that it will "not scuff the turf".(Yet this must the case, since we don't hear about them tearing up yards, and the design-choice(as given) is "either/or"!
Ditto NH.
To make the distinction between the old "very strong" Deere unit, and the new "weaker" one can easily give the impression that the competition's MFWD's are "heavier-duty", ...an impossibility, according to the design choice given above.
I.e.; either you CAN have both, (strong/no-scuff), because the K. and NH. engineers have done it, ...or you CAN'T(because a design-choice is necessary), so K. and NH. don't have both either.
If this "choice" is a design fact, then ALL MFWD tractors that don't-scuff have weaker-than-the-"old"-Deere limited-slips.
In other words, the Deere unit has been "weakened" only to a level equalling the competitor's, ...which we are given to believe, are plenty rugged-enough!
If this is the case, then discussing the new "weaker" Deere unit with no mention of the relative performance of the others can easily give a "weighted" impression. The "objectivity police" are watching! /w3tcompact/icons/cool.gif
Anything wrong with this reasoning? (logically based. I believe, on the "can't have both" proposition)
Larry
