Tires John Deere 4320 Wheel Spacers??
   / John Deere 4320 Wheel Spacers?? #1
JDRULES
Western New York State
JD 4320
This past June I traded up to a John Deere 4320 from a 3320 and just learned that there is not enough room in the standard rear wheel position for the road chains that came with the new tractor, as they will rub against the inside of the fender. So I turned the wheels like had been done for the 3320 and the wheel width is now unfreaking real! It's now slightly wider than my 84 inch rear blade. Has any one out there run into the same issue and had any success with adding a two inch skid steer (or other?) wheel spacer to a JD 4020 series compact? If so, what is the brand, product number, cost, and retailer you used? If only John Deere would not have taken the cheap skate route and discountinued the 8 position rims that they had sold on the 4020 series for years! I can't be the only one out there that needs to run tire chains on this size tractor. Thanks in advance for any recommendations.
   / John Deere 4320 Wheel Spacers?? #2
I experienced the exact same thing as you described with my 2010 4320. My 2007 4320 did not have the issue because the rims were adjustable as you mentioned. I installed 2" wheel spacers on the 2010 model and that has worked well. A set of four spacers were purchased on ebay for about $300 with free shipping at the time. I used the other 2 spacers on my 3720 tractor to improve stability on steep hills. You can purchase a set of two spacers or a set of 4 spacers on ebay from several different sellers.
   / John Deere 4320 Wheel Spacers?? #3
As sunnyside360 said, the 2" spacers work very well... on my 4300.
and :welcome: to TBN
As sunnyside360 said, the 2" spacers work very well... on my 4300. and :welcome: to TBN
Folks......Thank you for the quick responses and welcome aboard!!
Would you know the specific size specifications that I need to assure that I order the correct size of the spacers for a proper fit? Would you have any links handy to get me to the right source on the web? Thanks again for the help!
   / John Deere 4320 Wheel Spacers?? #5
Sunny,
Thank you for the product info and older thread on the same issue to review. It was all very very helpful. Take care!
   / John Deere 4320 Wheel Spacers?? #7
Not sure if I mentioned it but the spacers for the 3x20 and 4x20 wheels are exactly the same. Good luck.
Sunnyside360,
With your skid steer solutions.com wheel spacers on your 4320 were you able to use your existing 14mm wheel bolt studs when mounting the 2" spacer onto the hub or did you need to purhase a longer size? If so, how long and where did you find them? Do you recall the cost?
Any one else out there with the same product and JD 3020 or 4020 series tractor?
   / John Deere 4320 Wheel Spacers?? #10
Sunnyside360,
The set I got came with all the studs needed to install the spacers. The only thing extra I bought was the blue thread lock to keep bolts from working loose.
2016 Chevrolet Silverado Pickup Truck, VIN # 1GC2CUEG6GZ333208 (A44391)
2016 Chevrolet...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A43004)
2020 INTERNATIONAL...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
3pt 5' Mower (A44502)
2016 Kubota RTV-X900 Utility Cart (A44572)
2016 Kubota...
John Deere 755C Series II Crawler Loader (A44391)
John Deere 755C...
