John Deere 4400 reliability.Is green a myth ?
   / John Deere 4400 reliability.Is green a myth ? #1
eee
West Virginia
I have had a JD 4400 for over 4 years now. I use the heck out of it and I have had some problems as well. I fix the thing and I go on.The tractor has 1116 hours on the clock.
The safety switch under the seat has failed.
1 fan belt replaced under warranty.
I have bent and replaced the lower lift arms.
I have had to replace the adjusting rod/bar on the left lower lift arm.(broke)
It had a new starter replaced under warranty because of a hard starting issue that was resolved by a piece that was replaced/ installed in the electronics.
I have had an intermitent loose wheel bolt problem.
I have my 3rd differental lock which has failed (about a year ago)I am not going to spend any more money on this part,I can use the steering brakes.
I had to replace both the axle housings.
I have the old style axle and had to replace both tie rod ends ( $210 apiece)
The plastic side covers do not stay in place very well the same with the front grill cover,there is not much holding the covers in place to begin with.One of the ears on the side cover is broken.
The plastic around the ignition switch is cracked.
I had to intall a new seat belt (button came apart)
Last night the speed range selector quit working. I was in the woods and I could not get the tractor into low range or any range,I crawled underneath the tractor and found the part that is pivoted by the handle and was able to get my channel locks on it and turn it,it went into low range. I had to help it with my channel locks one more time and when I got to the house I intentionally moved the selector out of low range and I then could not move it to any range regardless of what I tried to do. It appears I am going to have to tear into the tractor again and fix it right.
I have the 430 loader and 4 in 1 bucket,some of the hoses have been replaced because they are in an area that gets a lot of movement and rubbing on the loader arms.
The Yamnar engine has performed flawlessly ( 1100) The hydro has performed well.
I can't help to wonder if JD is coming out with the new line up of compacts because of the problems associated withe the 4000 and 4010 series.
I always liked green,but if I were to buy another tractor I am going to take the JD binders off and go look at Kubota/CNH/CASE/AGCO/ Massey. A neighbor of mine bought a new Massey Ferguson that is a 29 HP and I could see nothing wrong with it,I do not know if my JD would be a better value than his Massey after comparing the 2 tractors.
The biggest thing that kept me with JD is the strenght of the company and parts availability and the company not merging with anyone else.
I have several JD green implements,if I ever do switch I can paint the implements to match what ever brand I go with.
   / John Deere 4400 reliability.Is green a myth ? #2
</font><font color="blue" class="small">( I always liked green,but if I were to buy another tractor I am going to take the JD blinders off and go look at Kubota/CNH/CASE/AGCO/ Massey )</font>
If I bought again I'd do that anyway - even if I was 100% pleased with my JD. I like to know what the competition is up to, and who knows, they may have a demonstrably better product.
On the other hand - if the dealer has been supportive I would likely stick with him if the products were essentially equal.
I've had some minor issues with my 4310 - the most annoying relates to the wiring underneath the tractor. I hope on ANY subsequent re-design that they channel the wiring through some sort of protection. It's crazy how they've left it exposed on the underside - I caught it up again this past weekend - and that was after I "armored" all the wiring with duct tape /forums/images/graemlins/tongue.gif. Back to the drawing boards... I may have to buy real underbody armor yet. But other than that mine has taken a beating and keeps coming back for more.
   / John Deere 4400 reliability.Is green a myth ? #3
I have a JD 4600 with over 2000 hours of extremely hard use and I haven't done one thing to it. I'm surprised that you have had so many problems. It sounds like alot of the issues were from too much strain on the unit.
Like I say Doctor I have used the tractor very hard,I will definately go up in size on my next one. The 5000 series look nice. I blame myself for a lot of the problems and some I blame John Deere. Maybe I let my emotions get the best of me when I made the original post,let me get it fixed and back in the drivers seat and my mood will improve.
   / John Deere 4400 reliability.Is green a myth ? #5
I certainly understand your frustration. I often wonder how well some of the other brands would hold up myself. Very few people here use their tractors hard enough to really see what they will do and how they will hold up to stresses at the end of their capacity.
To be honest I have expected my loader to break, hitch arms, etc. But I really wouldn't blame the tractor for that as I know that I am really pushing this thing beyond what it was capable of.
I have close to paid for the tractor with my timbering work. I never dreamed when I bought the tractor I would get the amount of use out of it I have.
   / John Deere 4400 reliability.Is green a myth ? #7
Good point - I've worked mine hard - and it shows - it's kinda scratched, a dent in the brush guard, and one cracked ROPS light... but it still runs well and strong. I figure I would have paid somewhere in the area of 8 to 10 thousand for the work I've done so far - in my mind the tractor is paying for itself. I'm about to send it in for it's 150 hour service... I think I'll have them go through it and get it as close to new as possible. I'm not worried about looks, just anything it might need mechanically. It's earned it's keep so far and I think I owe it a good mechanical massage.
   / John Deere 4400 reliability.Is green a myth ? #8
Yup, it is easy to get frustrated when something is broken...
It might help to take your own list and categorize it:
Stuff that broke for no good reason. (manufacturer defect or design fault)
Stuff that broke that was purely my fault.
Stuff that broke that are due to the combination of design fault, and my snagging it...
Then when considering a new unit, check to see what has been improved by the manufacturer. And DO look at other brands that will also provide good support. What have they addressed that will help you?
Interesting that you mention timbering. Many of us are using machines that have an ag heritage in all sorts of brush. Someone that uses theirs in improved fields doesn't need to pay extra for some of the protection we need.
So when looking at an upgrade, factor skid plates into the package!
<font color="blueclass=small">( <font color="blue"> Very few people here use their tractors hard enough to really see what they will do </font> )
Thats like how many people have 4WD and actually use the 4WD,let alone the low range, </font><font color="blue" class="small">( <font color="blue"> in there SUV's and trucks etc. </font> )</font>
   / John Deere 4400 reliability.Is green a myth ? #10
I have a question and a comment for you. First, since I just replace both sides of my rear axle housing last weekend, I wonder if you could tell me what happened to cause you to replace yours?
Lastly, I noticed that you wrote that you had to replace some of the hydraulic hoses for your 4 in 1 bucket on your FEL because they were damaged by rubbing on the loader arms. I just spoke with my Deere dealer today about getting a 4 in 1 bucket for my 4200 and remember him telling me that the set of hoses for that bucket are braided lines just to prevent the problem you describe. The hose set was something over $300 but the steel braiding over the hoses are designed to protect them from the kind of wear and subsequent damage you describe. Do you have the braided lines Deere recommends or regular unprotected hydraulic hoses?
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
1989 BOMAG BW213D SMOOTH DBL DRUM ROLLER (A52707)
1989 BOMAG BW213D...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
2013 JOHN DEERE 27D EXCAVATOR (A52707)
2013 JOHN DEERE...
2017 JCB 510.56 10,000lb 4x4 Rough Terrain Telehandler (A55851)
2017 JCB 510.56...
