John Deere 455 Garden tractor
   / John Deere 455 Garden tractor #1
caseyvand
Dunvegan, Ontario, Canada
Hi.....Does anyone have any idea or knowledge about putting a tachometer on the Yanmar engine.
Thanks.....Casey
   / John Deere 455 Garden tractor #5
Sounds like there is an easy answer so this is probably more than you want to do. But FWIW you might be able to add a factory mechanical tach. The 755 also uses the 3TNA72 engine. The drawings show the 455 has a cover plate where the tach gearbox attaches on the 755. The gearbox along with the cable and tach could probably be added to the 455. This would be more expensive than the Tiny-Tach. Those three parts add up to about $175. The tach alone is $100 dollars of that total.
HI....Yes that looks like a possibility. The tiny tach is a nice tidy package for about $100 and I'd guess 1-2 hours labor. (I'm a slow worker). Thanks for the info. I'm also investigating a heater for the cab.
Thanks.....Casey
   / John Deere 455 Garden tractor #7
On the JD 455 Yanmar diesel, would the transducer be mounted to one of the three fuel lines after the injector pump?
   / John Deere 455 Garden tractor #9
   / John Deere 455 Garden tractor #10
Well, yes I have experience with Tiny Tachs. But not on diesels. I have several on gas engines and they just work and work year after year. I would highly recommend them.
There are other versions out there that look a lot like a Tiny Tach ---- they aren't so good. Stick with Tiny Tach.
1999-2010 Ford Pickup Truck Bed (A52377)
1999-2010 Ford...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2014 FREIGHTLINER M2106 BUCKET TRUCK (A51406)
2014 FREIGHTLINER...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
