John Deere 455 with no throttle after short circuit
   / John Deere 455 with no throttle after short circuit #1
Hannumal
John Deere 455, John Deere GX75
Greetings! I was happily mowing grass with my JD 455 diesel when the mower suddenly shutdown, then two seconds later there was a pop sound from under the hood and the dash lights went out. Apparently the fuel shutoff solenoid failed and short circuited. It melted some of the solenoid and the solenoid's wire connector before one of the main 15A fuses blew.
I replaced the solenoid and all the fuses, but now the tractor will not throttle up past the minimum idle RPM. The throttle lever is firmly connected through the throttle cable to the fuel injection pump, but adjustment to the lever have no effect at all on the engine speed. This has got to be related to the short circuit, but I don't know where to focus my attention. Is the fuel injection pump electrically powered? Will the tractor even idle if the fuel injection pump has failed? Is there another sensor I can check that could prevent the tractor throttle from having any control function? I should mention, the new fuel shutoff solenoid works great and I can hear the fuel pump under the seat running then I turn the key on. The tractor will idle for several minutes if I let it. All help is appreciated.
   / John Deere 455 with no throttle after short circuit #2
Welcome to TBN:welcome:
Do you have the service manual the your tractor?
There is a lot of help in it.
Richard
   / John Deere 455 with no throttle after short circuit #4
It may have taken out the the key/ignition/safety module (board).
   / John Deere 455 with no throttle after short circuit #5
With the key on and the tractor not running, can you hear the fuel pump?
I've cooked the one in my 430 diesel twice...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
2008 INTERNATIONAL 9900I (INOPERABLE) (A55745)
2008 INTERNATIONAL...
New Holland WorkMaster 37 (A53317)
New Holland...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
