John Deere 4720 cab vs Kubota GL5030 cab
   / John Deere 4720 cab vs Kubota GL5030 cab #1
Pokeboater
Macon, Georgia
John Deere 4520 cab
I was ready to buy a Kubota with a cab and then found out John Deere has the 4720 in a cab. The dealer (sells both) recommended the Kubota (less $). My question is the cab. John Deere claims a 30 degree temperature differential and Kubota claims 7-14 degree differential with the cab. Does this mean for the Kubota, if it's 100 outside it will only be 86-93 on the inside? I've got a 4710 now (no cab) that I'm happy with but I'm in south Georgia and it gets real hot and real humid down here and I want to be sure the cab will be cool enough. As to John Deere vs Kubota, I really don't have any brand loyalty. Thanks!
   / John Deere 4720 cab vs Kubota GL5030 cab #3
My suggestion is to go sit in the two and drive them and make your decision. The Kubota cab did have some serious problems with their AC a year or so back. I'm not sure if they got that fixed or not. The Deere AC will give you no problems at all. I had one the end of last summer when it was hot and humid and in a couple minutes it was as cool as you would want it.
   / John Deere 4720 cab vs Kubota GL5030 cab #4
The problem is that it's not very hot now and I need to go ahead and get the tractor.
   / John Deere 4720 cab vs Kubota GL5030 cab #7
I can't say I've ever heard of problems with the Cab A/C system? One thing to keep in mind is the bigger the AC compressors the more HP they take from the Engine. The Kubota system uses 3 engine HP... if Deere is really able to reach a much lower temperature its going to be at the expense of exponentially more engine power.
   / John Deere 4720 cab vs Kubota GL5030 cab #8
   / John Deere 4720 cab vs Kubota GL5030 cab #9
Pokeboater;
The temperature differential means that the a/c system sends cooler air to the vents for the upper body and a slighter warmer air for the vents used to cool the lower body. I don't think it has anything to do with how well it will cool in relation to outside temp. My GL5030 is open station so I can't comment on how the Kubota system cools. I can, however, say that I am very pleased with the rest of the 5030. I suggest you post a specific question on the Kubota Owning/Operating forum something like "GL5030 A/C Trouble?" and see what you come up with. There are lots of great folks on this site that always willing to help out and I am certain they would let you know if this is indeed a concern. Good luck!
   / John Deere 4720 cab vs Kubota GL5030 cab #10
Pokeboater;
HARDEE RD72M LOT NUMBER 154 (A53084)
HARDEE RD72M LOT...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2023 JOHN DEERE 2032R LOT NUMBER 164 (A53084)
2023 JOHN DEERE...
2004 JOHNSTON STREET SWEEPER (A52577)
2004 JOHNSTON...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
