John Deere 5103 injector solenoid fuse blown
   / John Deere 5103 injector solenoid fuse blown #21
Since it is a temperature sensor, the resistance will change between when it is hot and cold. Did you try putting it in a hot glass of water? If yes, what was the resistance then?
Looking at JDparts the temperature switch range is 100 degrees Fahrenheit to 122 degrees Fahrenheit.
   / John Deere 5103 injector solenoid fuse blown #22
I did not measure it when hot, only at room. I did compare the bad sensor to the new one. The bad sensor had an electrical connection to the brass housing, thus to tractor chassis ground. It seems to be in the range of 5-30 ohm, but I was not trying hard to find the best tractor chassis ground.
So this is the failure mode. The new sensor did not have this shorted path. This sensor seemed to fail after some hard freezes we had, even though I keep my tractor inside an enclosed tractor barn.
Year: 2019 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2019 Make...
2008 VIKING TRAILER 40+5 LOADER TRAILER (A58214)
2008 VIKING...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
utv cart Honda (A56857)
utv cart Honda...
