John Deere 5400 - 3 Point Hitch will NOT Drop
   / John Deere 5400 - 3 Point Hitch will NOT Drop #1
dnkjr
Austin, TX
John Deere 5400
Inherited this tractor from my Dad who bought it new (1995). It has only 85 run hours and is used to shred or disc 3 acres a few times a year. When I hooked up to the shredder, it lifted a usual. When I got to the field, it would not lower. I called a dealer, who said that the rockshaft valve may need cleaning. I have removed the seat, rockshaft/draft handles and shroud. I also jacked up the shredder on 3 sides to take some weight off the 3-point hitch.
Questions:
1. Are the parts to be serviced/cleaned contained in the approx. 2" x 2" casting that has the rockshaft and draft control levers on the outside end?
2. How to get to the rockshaft valve? I assume it is inside the rockshaft housing.
3. Will there be hydraulic pressure on that part? If so, how or where is the safest best way and place to release the hydraulic pressure?
4. How much oil will I have to catch?
5. How and with what should the valves be cleaned?
All help and info appreciated.
   / John Deere 5400 - 3 Point Hitch will NOT Drop #2
i don't know the answers, but I have a PDF of the Deere tech manual you're welcome to, shoot me your email if you want it. I'm sure the answers are in it.
JOE
   / John Deere 5400 - 3 Point Hitch will NOT Drop #3
Be sure the rate of drop screw(parts key #8) under the seat isn't completely closed.
   / John Deere 5400 - 3 Point Hitch will NOT Drop #4
9 times out of 10 that is the fix when people come on here with a 3 point that wont drop.
Aaron Z
JOE - I'd sure appreciate the PDF. My email is [U]dnking59@gmail.com[/U].
Thanks for responding...dnkjr
Jim - Thanks for the lead. That's the knob under the seat? I don't think we ever moved the setting, but will double check. dnkjr
aczlan - Thanks for the lead. I don't think we ever moved the setting, but will double check. dnkjr
   / John Deere 5400 - 3 Point Hitch will NOT Drop #8
Aaron Z
Yep those things get bumped with your feet and then vibration will also close them. Happens about once a year or so for me.
   / John Deere 5400 - 3 Point Hitch will NOT Drop #9
Also, if you have kids, that knob gets moved. Although, if you ask, they never came close to the tractor.
MoKelly
   / John Deere 5400 - 3 Point Hitch will NOT Drop #10
shop manual link on the way shortly
Joe
2014 Ford F-150 Ext. Cab Pickup Truck (A44572)
2014 Ford F-150...
Ryobi Compound Miter Saw (A44391)
Ryobi Compound...
Graco Rental Pro Airless Paint Sprayer (A45336)
Graco Rental Pro...
2014 Freightliner M2 106 Medium Duty Truck, VIN # 1FUBCXCY7EHFR7050 (A44391)
2014 Freightliner...
2007 STERLING A9500 TANDEM AXLE DAY CAB (A43004)
2007 STERLING...
2018 HINO 195 17FT BOX TRUCK (A43004)
2018 HINO 195 17FT...
