Posted this at Yeserday's tractor so some of you may have already seen but thought I would post these here too.
This old hay rake was my father-in laws and had not been used in 18 years. It was in extremely poor condition and had extreme sloppiness due to wear almost everyhere:
a) I replaced every bolt with grade 5 hex heads bolts(which replaced grade 2 square head bolts and nuts which were worn away to almost nothing from running loose for years).
b) Made all new bushings from scrap pipe for the tongue, adjusting levers, and chain pulleys.
c) Used about 3 lbs of Mig welding wire used to build up parts and do repairs as needed.
d) Put the bars "in time" as they were out of time.
e) Rattle can paint job to spruce it up.
f) Matching the casting codes it is somewhere between a 1940-1948 unit - my repairs should make it usuable for another 50 years.
G) Note the ingenuis home fabricated conversion to steel wheels by the previous owner to replace the original 4 x 36" rubber tires which had deteroraited. (New replacement rubber tires at $230 each would far exceed the value of the rake).
