robert clarke
Just noticed the diagrams in this site after I entered the posting. Look at the diagrams and you will see the flow restrictor valve that I was talking about. It is #6. One end is completely open but the other end is closed off with a smaller hole drilled in it, to reduce the flow getting back to the return line and on into the fuel tank. Also I got the prices reversed for the one way valve and the flow restictor valve. One way valve $29.95 CAN. and flow restictor valve $4.50 CAN. If you want to see if that line letting fuel get back to the return line and to the fuel tank is the problem, before making any investment in parts, - just use your vise grips and clamp that line closed so nothing, or very little fuel can get back to fuel tank, - and run electic fuel pump for a minute or two before starting engine. If the engine runs properly then you just proved to yourself that you need that part #6 - the flow restictor valve. I just think the one way flow valve is also a good idea for all it costs.
