John Deere 650 180 deg coolant thermostat
   / John Deere 650 180 deg coolant thermostat #1
Tmar104
1991 kioti lb1914
I have JD 650 with OEM 160 deg thermostat and want to replace with 180 deg thermostat. Anyone have part numbers? I’ve searched but no luck. I know this has been before. Thanks to all
   / John Deere 650 180 deg coolant thermostat #2
That's a Yanmar engine isn't it? I sort of remember that size Yanmar used a 190 degree thermostat.
I'm not sure I've ever seen anything under a 180 degree thermostat.
Anyway, with the JD 650 - or any of the early Yanmar built JDs - you will get a lot more info if you drop down to the Yanmar forum below here and ask there.
   / John Deere 650 180 deg coolant thermostat #3
This link may interest you. Appears the part number for the 160 deg also fits your JD 650.
   / John Deere 650 180 deg coolant thermostat #4
Bring your old thermostat to your local parts store & try to match it up with one that’s close enough that you could modify size wise to fit.
I did that with my Ford 1720 & installed a 190 degree thermostat.
I had to reduce the OD a bit for it to fit. It’s been in there for 10+ years no issues.
90cummins
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
3 pt Aer-Way (A50514)
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
2018 CATERPILLAR 336FL EXCAVATOR (A51222)
2018 CATERPILLAR...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
