John Deere 650 3PT lift capacity
   / John Deere 650 3PT lift capacity #1
warrendeere
1985 John Deere 650, 2002 New Holland TC35D, 2000 John Deere 4200 HST
Hi all, wondering the specs of my 1985 John Deere 650. I am planning on putting a 54" Box blade on it, and I need to know if it can handle about 500lbs. The box blade weighs 295lbs, but I figure with dirt it will weigh more. Any idea of my 3PT hitch lifting capacity?
   / John Deere 650 3PT lift capacity #2
From this John Deere site:
Specifications
3-Point Hitch
Type Category 1
Lift Capacity- (24-in. behind link arms) 370 kg ((815 lb)
Dave M7040
   / John Deere 650 3PT lift capacity #3
You can lift it. My Yanmar YM186D came off the same assembly line and is comparable in size. I use a 4 ft Howse rotary mower, 464 lbs, and the center of that weight is much farther back than a box blade. I also have a 750 lb 3 point backhoe on my larger tractor that the little YM186D can't lift.
However ... I'm not sure you have the weight and traction to do useful work with a box blade that size. It may simply anchor you to the ground. My little tractor, about the size of yours, came new with a 4 ft blade and that's what feels right for it. The 5 ft blade I bought for the 24 hp YM240 needs some passes with the scarifiers before it will lift and carry dirt. I'm not sure that larger one is more productive overall.
I think the advice you need is 'how wide a box blade can I pull with a 1600 lb tractor?'.
Also - take a look at this TractorData page for your Deere 650.
Thanks for the advice. And have a good one.
well actually the ym186d weighs 101lbs lighter than my 650. Yes these tractors shared similar parts, but they were i fact a different design.
1995 CLEMENT LC9L 48FT ROLL OFF TRAILER (A45677)
1995 CLEMENT LC9L...
2016 Ford Focus SE Sedan (A44572)
2016 Ford Focus SE...
2008 Lincoln Navigator (A46684)
2008 Lincoln...
1996 JLG CM-2033 20ft Scissor Lift (A44571)
1996 JLG CM-2033...
2006 FREIGHTLINER M2 106  TANDEM AXLE 28FT MOVING BOX TRUCK (A45677)
2006 FREIGHTLINER...
PENDING SELLER CONFIRMATIONS ON SOME LOT #'S (A45677)
PENDING SELLER...
