Tires John Deere 650 Turf Tires
   / John Deere 650 Turf Tires #1
PoodlePimp
John Deere 650
Does anybody know if the John Deere 670 Turf tire rims will fit on a Jonh Deere 650? They both use 31 x 15.5 x 15 tires. I checked the Deere web site and the part numbers are not the same:
the 650 uses a part number CH15049
the 670 uses a part number M802863 or AM877013
The rims physically look the same....... did they change numbering systems or are they really different??? Thanks TJ
   / John Deere 650 Turf Tires #2
Looking at the parts breakdowns, it does appear to be 2 totally different front axle designs.. and the hub where the wheels bolt to probably are different. If you can verify the bolt pattern etc is the same, then it might fit, but it's tough to see on parts screens..
good luck
Hey Dutch445. I should have mentioned in the post that these are the rear tires, 31 x 15.5 x 15.
Does anybody know if these 670 rims would fit on the back end of a 650??? TJ
   / John Deere 650 Turf Tires #4
I am looking for 2 rear rims with or without tires for a John Deere 650 . The tire size is 9.5-16 on an 8" rim.
Any one know where to look?
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50322)
2016 Hurricane...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
2015 Z Master Professional 5000 Series 60in Zero Turn Commercial Mower (A50322)
2015 Z Master...
