Tires John Deere 650 Turf Tires
   / John Deere 650 Turf Tires #1
PoodlePimp
John Deere 650
Does anybody know if the John Deere 670 Turf tire rims will fit on a Jonh Deere 650? They both use 31 x 15.5 x 15 tires. I checked the Deere web site and the part numbers are not the same:
the 650 uses a part number CH15049
the 670 uses a part number M802863 or AM877013
The rims physically look the same....... did they change numbering systems or are they really different??? Thanks TJ
   / John Deere 650 Turf Tires #2
Looking at the parts breakdowns, it does appear to be 2 totally different front axle designs.. and the hub where the wheels bolt to probably are different. If you can verify the bolt pattern etc is the same, then it might fit, but it's tough to see on parts screens..
good luck
Hey Dutch445. I should have mentioned in the post that these are the rear tires, 31 x 15.5 x 15.
Does anybody know if these 670 rims would fit on the back end of a 650??? TJ
   / John Deere 650 Turf Tires #4
I am looking for 2 rear rims with or without tires for a John Deere 650 . The tire size is 9.5-16 on an 8" rim.
Any one know where to look?
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
1990 Ford Ranger Pickup Truck, VIN # 1FTCR11TXLUC19238 (A51572)
1990 Ford Ranger...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2003 KENWORTH T2000 (A52472)
2003 KENWORTH...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
