John Deere 755 Engine/long/short block needeed
   / John Deere 755 Engine/long/short block needeed #1
Charlie_Iliff
Arnold, MD
Power Trac PT1845, John Deere 2240, John Deere 950, John Deere 755, Jacobsen Turf Cat II
755 threw a rod through the side of the block. (Still runs on 2)
Would appreciate any recommendations for sources of rebuilt engine/long block /short block.
   / John Deere 755 Engine/long/short block needeed #4
are our small diesels not like the larger cousins?
ie braze up the hole, put a new linner in the block and your good to go?
ive seen guys "repair" fist sized holes in the sides of blocks of older big diesels.
Don't know if the cylinders are lined, but will find out when we tear it down, if not before. I've repaired holes with Marine Tex, and certainly a good guy with the right rod for cast can do it.
The reason for loking for a long block is because the rest of the engine is probably a bit tired.
   / John Deere 755 Engine/long/short block needeed #6
Not sure if this'll help or not. A good listing of tractor salvage yards here.
SalvageYards
2013 Ford Taurus AWD Sedan (A51694)
2013 Ford Taurus...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2018 FREIGHTLINER BOOM TRUCK (A51406)
2018 FREIGHTLINER...
20711 (A50323)
20711 (A50323)
Light Tower (A52377)
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
