Price Check John Deere 790
/ John Deere 790 #1
gonzman
Deposit, New York
John Deere
Hi!
I've needed a tractor for quite some time now for 15 acre land. I want to brush hog ten of the acres and farm the five acres. A neighbor has offered me his JD 790 with FEL, Snowblower, Finish mower (not mid-mount) and a cab. It's a 2000 and 1092 hours - my neighbor has taken great care of the tractor. Mainly for mowing and snow blowing and has changed the oil regularly and has all the records since he first purchase the tractor new. I'm in the Central New York area and the price he is asking is 10,600.00. Is this a fair price? Not sure how to check the price since all the internet information varies quite a bit.
Thank you!
/ John Deere 790 #2
Compare the prices on TractorHouse to see if that's a good going rate he's asking. Of course you have to factor in all the implements too.
The John Deere 790 is built by Yanmar in Japan and is an excellent machine. Do your research to see if it has the PTO power needed to perform the tasks you want to accomplish.
/ John Deere 790 #3
Have looked on Tractorhouse.com?
From what I see there it's reasonable. I had a Deere 850 that was needed very little attention to keep running. The only reason I traded was I started having trouble clutching due to a bad back.
/ John Deere 790 #4
I would grab that machinery ASAP. You may not think about using the finish mower for brush hogging, but all you need to do is make a few runs with the mower elevated and go slow. Gator type blades even better. Then its easy to stay on top of it year round. You could even sell the snow blower and front hitch combo for a few thou$and and go with snow some other way.
You can easily run a 9' hay mower and a vintage baler to make some horse hay bales to sell. That's what I do.
/ John Deere 790 #5
I paid $10,500 for my 2004 790 (385 hours) w/300 loader & 5' Woods 3-pt finish mower around six years ago in southern IA.
With what you're looking at, if everything's in good condition, that doesn't sound bad to me!
/ John Deere 790
Thank you for the response and the ideas. I was was wondering about using the finish mower for brush hogging, but I wasn't sure it could pull it off. Thanks again.
/ John Deere 790
Yes, I checked tractorhouse, but was thrown off with prices close to 10k with less hours. However, I do need to take the implements into consideration and that's where I got lost.
Yes, it's 4 wheel drive. I will do further research regarding the PTO power for the tasks. Now I have more confidence in going forward with the purchase - Thanks for the responses!
/ John Deere 790 #9
buying from a known seller add value in my opinion.. You may find one cheaper, but was it abused..
The 790 is a 'bullet proof' tractor.. - BUT im not sure if i would want to mow 10 acres with it on a regular basis, unless you like seat time - the recommended rough cut mower is only 5' wide I believe (that is what my dads is)..
brian
/ John Deere 790 #10
I had a 770 bought new. Same machine just the older version. I got rid of it because it was not hydro. The gear/speed selection was limited. I had a front blower but going back, you only had two speeds. With the revs up for blowing, one range was too fast, the other too slow!
In fact one guy gave me a deposit, and then called saying he was informed about the (non hydro) transmission. I was nice enough to refund his deposit. A neighbor bought it.
Great machine, high quality, Nice Big Tire Size (Which is what attracted me to it). I bought it on sale, but had a hard time getting enough money for a barely used machine. Fortunately, I had found the front blower cheap at auction that made up for it. The neighbor has been happy with it, lately only cutting grass with the belly mower..
/ John Deere 790 #11
My 3005, which is a 790 with new badge number, has done very well for me, for all the bigger it is. I have 118 acres of prime grade A West Virginia hillside... about half wooded, half overgrown pasture fields. I've been working my lil tractor hard, with 5' brush hog, on the fields, but it gets it done. It's slow, and as mentioned above, the reverse gears are too low compared to forward gears, of mine were just a little faster backwards in low range, it would be better.
Mine gets run wide open, and at about 365 hours, still runs like new. I've built a full brush cage with limb risers and screen on the back behind the ROPS, made wheel spacers to gain 4.5"ea/9" total, and sometimes carry a 5' piece of railroad track for ballast. RR track in bucket for brush hog ballast when on really steep hills, on the box blade for loader work. All 4 tires are loaded.
D@mn good little machine.
/ John Deere 790 #12
JD 790 can only operate a 48" Rotary Cutter; AKA Bush Hog. Allowing for 6" overlap, effective cutting width is 42". It will take a very long time to mow ten acres.
/ John Deere 790 #13
I have always pulled a 60" bush hog with my 790. No sweat at all...
/ John Deere 790 #14
5' Frontier cutter here: Farm 2016 054.JPG No problem pulling it at all, I use it for heavy grass & weeds. Also have an old JD 5' cutter for brush cutting, HPIM3351.JPG Only problem with it is the lower 3-pt pins are a little too wide, so the arm rub the tires at times.
PALLET OF MISC PARTS (A63291)
PALLET OF MISC...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
Caterpillar D8N Dozer Service and Parts Manuals (A63117)
Caterpillar D8N...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
