John Deere 855 Front Wheel Bolts Loosening
   / John Deere 855 Front Wheel Bolts Loosening #1
DudeJohnDeere
Walworth, NY
1940 Allis Chalmers B, 1992 John Deere 445, 1998 John Deere 855, 2001 John Deere SST18, 2007 John Deere Gator TX and many others at the farm yard
Anyone have any suggestions as to what may be causing the lug nuts in the front wheels of my John Deere 855 to loosen up?
I did the 500 hour service about 4 years ago, about 1 year before the problem started. When I changed the transaxle oil I was not aware of the breather plug on top of each final drive, something I was just made aware of a few weeks ago. I spend a lot of time working on row crop tractors at my day job, but I am fairly unfamiliar with the compacts. My theory is that since the breather was not opened, no oil got down into the final drive, causing the bearings to wear. With the wheels off, I can push/pull the flange that they mount to about an 1/8 inch in either direction. the parts to rebuild the final drives total almost $2700 and I need new rims which total $400, so I want to be sure I am making the right repair. Thanks for the help.
   / John Deere 855 Front Wheel Bolts Loosening #2
I would not be concerned with the in and out movement. I would be more concerned with up and down or side to side play. I also do not believe the breather being clogged would prevent oiling. The more likely issue with clogged breather would be pressure causing a seal failure.
Any other symptoms that make you think the final drive needs rebuilt?
2022 JOHN DEERE 6120M LOT NUMBER 192 (A53084)
2022 JOHN DEERE...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
SHOULE PWD-10 LOT NUMBER 133 (A53084)
SHOULE PWD-10 LOT...
20ft Utility Cargo Trailer (A51572)
20ft Utility Cargo...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
