chriswheeler
Platinum Member
Yes, I'd re-ring it, you are already there. 1000 hours isn't much for these, I bet the rings are fine most likely, but rings are cheap and with freshly honed sleeves, it freshens up the whole assembly. I just used all thread and scraps of steel I had laying around, it didn't take much of a pull to break them loose, and you don't have to move the liner much until you can remove them by hand. Think I remember using 3/4" course thread all thread and they came right out. Spent some time cleaning up the sealing surfaces in the block where the new O rings will seat, got them spotless. In your case, I'd be looking closely at the seating surface in the top of the block for signs of a leak. If there is one, you will see it. But most often it's the O ring that fails and after removing the sleeve, most likely won't be able to tell looking at the ring. Sounds like you are almost halfway done at this point, the rest is down hill. If you have a machinist friend with micrometers, ( inside and outside ) it would be good to measure the bores of the sleeves for any taper and the pistons to see if they are still in spec. If you don't have a friend with the tools to measure, I wouldn't worry to much about it with only 1000 hours on that engine, most likely just fine. A word on the hour meter on that one, you probably know that engine hours are measured @PTO rated speed, so depending on what it was used for, it has more, just no way of knowing what the actual hours are.
Chris
Chris
