John Deere 990
/ John Deere 990 #1
lazy b farms
white deer texas
6640 see
Needing some help on my 990. For some reason the crankcase is filling with Diesel. Drained nearly 2 and a half gallons out today. Where could it be coming from? Any help would be greatly appreciated.
/ John Deere 990 #3
There are three possible routes for fuel to enter the lubrication system
Fuel lift pump – The diaphragm can split providing a route for diesel to enter the engine crank case.
Injector pump – Injector pump shaft seals have been known to fail.
Damaged Injectors – Leaking injector nozzles during periods of inactivity can drip their contents into the cylinder which then runs down between the piston and bore into the sump.
/ John Deere 990
Finally got back on it this afternoon and removed the fuel pump and injection pump. Planning on taking them in to have checked out. I am wondering though if tractor starts and runs good could it still be an Injector? Starts right up every time and smokes very little.
2024 JCB 35Z (A60462)
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2006 Acura RL Sedan (A59231)
2006 Acura RL...
