John Deere Ballast Box
   / John Deere Ballast Box #1
NYBOB
Maine NY(Binghamton area)
2007 JD 3720
I had a thread last year on the JD Ballast box and filling it with concrete. I am ready to tackle that job but I need some help.
1)I believe portland cement was the heaviest and I needed 5 or 6 94lb bags.
2)Since I have not worked with cement before, do I mix it right in the ballast box, one bag at a time.
3)I remember one poster said I should caulk the inside of the ballast box. I also was told to drill holes where the PCV pipe that I will use to hold tools will come out the bottom. My question is, while pouring the cement, how do I get the PVC to stay where I want it?
4)I have a pallet with wheels on it that can handle 1000 lbs, should I go a little less cement to make sure it is under 1000 lbs? How many bags would be just under 1000 lbs?
Bob
   / John Deere Ballast Box #2
I looked at them but thought it easier to start a new one. I need some instructions on how to do it.
Bob
   / John Deere Ballast Box #4
As far as weight goes portland cement weighs in at 94lbs per cubic foot. Personally I would mix your cement outside of the box to insure you get a thourough mix. As far as your other question I don't know.
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
74in FEL HD Round Back Bucket (A52748)
74in FEL HD Round...
KSI Conveyor (A52748)
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52748)
Texas Post Driver...
