John Deere Freedom 42 Mower Deck
   / John Deere Freedom 42 Mower Deck #21
I have a John Deere Freedom 42 mulching deck, but have no idea what it came off of. Is this a multi-fit deck or is it for a specific application? The deck I have is complete and in perfect condition; I just want to sell it.
I've got one on an LX255. Cuts like a charm if I have it set-up correctly. Biggest problem for me is getting the timing belt set correctly.
   / John Deere Freedom 42 Mower Deck #22
My Freedom deck is doing the same thing. I just changed the belt and as you spin the blades they eventually hit. I unfortunately cannot find a diagram for routing either belt. Any help you could give?
Thanks
Randy
   / John Deere Freedom 42 Mower Deck #23
Thanks
Randy
Wow, this thread was originally started in 2005! That's bringing it back from the dead, but you're still on topic.
It's been several years since I owned one of these decks, but the blades have to be positioned in such a way that they're timed to miss each other. If you were looking at the deck while it was standing up on it's rearmost edge, one blade would be straight up and down (like 12:30 on a clock) and the other would be straight across (like 2:45) if I'm recalling things correctly.
   / John Deere Freedom 42 Mower Deck #24
I did that and opposed the dots on the pulleys, set the deck up on end for a visual, and spun the pulleys. Within 50 or 60 turns they are hitting again. I'm at a lose.
Thanks for responding and i'll go play with it some more.
Thanks
   / John Deere Freedom 42 Mower Deck #25
Thanks
Sorry that I didn't quite steer you in the right direction, but as I say I was trying to go by memory of several years and many mowers ago. Hopefully someone with more accurate & recent information than I will chime in here.
   / John Deere Freedom 42 Mower Deck #26
I figured it out. There is a spring tensioner for one of the pulleys. I adjusted the pulley, which in turn tighten the belt. It stays in time now and I mowed a copy of strips in the rain.
Thanks for the responses.
Randy
   / John Deere Freedom 42 Mower Deck #27
I have the same problem with a used LT 155 w 42 Freedom mulching deck I just purchased. It leaves about a 4-6 inch uncut strip in the middle of the cutting path. I checked the blade arrangement (perpendicular to each other) and the length of the blades is such that they should be overlapping cut in the middle instead of not cutting in the middle. My original LT 155 which I have had for 6 years or more has been the best mower I have ever had. That's why I got this second one used as JD does not make thus model any more and the X300 series they now sell as a mulching mower is extremely inferior to the LT 155. In fact I bought one of those to have a second mulching mower and finally bought the regular cutting deck for it to replace the poor performing mulching deck originally purchased with it. Anyway, wish someone could help solve the non-cut center area.
   / John Deere Freedom 42 Mower Deck #28
1 blade's pulley is 2-3 inches in front of the other blade so that they can overlap. If the grass is not stiff, meaning a bit wilty from drought or lack of water, there will be a strip in the middle. Sometimes, tall weeds don't get knocked down if they are ran over near the edges. I guess these decks just don't have that good of a "vacuum" effect like a good ole Snapper Hi-Vac single blade. I have a gravel road and am constantly having to sharpen my blades from hitting or sucking up gravel rocks.
My deck might be a 42" "Edge", is that the same as you are talking about?
   / John Deere Freedom 42 Mower Deck #29
I have an LT166 with 42 inch freedom deck. I have been told they split the serial numbers and parts in the middle of the production year. I only find model number on boilerplate on back of tractor. Don't know where to look for Serial Number. I just need to find correct number for the deck timing belt, Don't know if it is the 225 tooth belt.
   / John Deere Freedom 42 Mower Deck #30
Wow, the thread comes back again.
I have one of these decks on my SST-16 which has to be the worst tractor Deere ever made.
My serial number is on a big tag stuck on the engine.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
Tractor Cab (A49251)
More info coming soon! (A46684)
More info coming...
45006 (A48082)
45006 (A48082)
7' yard gates, 14' Span Total (A47371)
7' yard gates, 14'...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
