JOHN DEERE - L120 TUFF TORQ HD K46 PROBLEMS
   / JOHN DEERE - L120 TUFF TORQ HD K46 PROBLEMS #1
jay516red
AMITE,LOUISIANA
JOHN DEERE - L120
HI, MY NAME IS JAY AND I AM NEW AT THIS AND MY L120 TUFF TORQ K46 IS STARTING TO SLIP GOING IN REVERSE. NEED PROBLEM SOLUTIONS,AND HELP.
   / JOHN DEERE - L120 TUFF TORQ HD K46 PROBLEMS #2
Welcome to TBN. :)
   / JOHN DEERE - L120 TUFF TORQ HD K46 PROBLEMS #3
Welcome from NY!
thanks for the reply ,i will probably need all the help i can get.
   / JOHN DEERE - L120 TUFF TORQ HD K46 PROBLEMS #7
Glad to have you as a member! See you in the forums!!
   / JOHN DEERE - L120 TUFF TORQ HD K46 PROBLEMS #8
I too have a JD120 that is 7 years old at 182 hrs and it too slips in reverse and growls within the HST. The first thing that I found through one JD mower dealer was that the non-servicable transmission can require servicing with possible causes being loss of trans fluid through a missing or knocked off axle cap,the internal filter may need cleaning,and if it is left too long with the grumbles and growls it then needs parts replacing or I could replace the whole transaxle for $800.00. I was then two weeks later at a major regional JD dealer who gave me access to their workshop manager who sat me down and patiently fault found my possible problems through discussion. the end result was since my brakes still worked the transaxle was ok and that the problem would be with my seven year old drive belt and worn out tensioner / idler pulleys. Having too much fun on the yanmar to pull the L120 apart but he showed me his collection of L series belts and pulleys he has relaced and it made sense to me.... maybe this helps you but it is only my experience and fossicking through the web I found lots of reported L series trans axle failures but I have had a good run out of this mower for the work that it has done, and I may need also to service the transwarp drive after doing the drive belt and tensioner, pulleys...regards
   / JOHN DEERE - L120 TUFF TORQ HD K46 PROBLEMS #9
Welcome to the forum from Oklahoma.
Ken
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
2001 John Deere M665 (A50120)
2001 John Deere...
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2022 LOAD TRAIL GOOSENECK TRAILER (A52472)
2022 LOAD TRAIL...
