John Deere Model 71 drive chain issues
   / John Deere Model 71 drive chain issues #1
mattradintz
Glenwood City, WI
Bobcat CT230
Anyone know where to look first if my chain keeps jumping off on one of my row units on the tension idler assembly. It seemed to work better before I tore it apart and painted it....
Thanks!
   / John Deere Model 71 drive chain issues #2
Check for misalignment.
How do I check for misalignment? I order and installed new chain, sprockets, idler cam assembly, thrust washer... basicall everything inside the drive unit and it is still skipping off the 2 small 7 tooth idler sprockets. Getting a little frustrated.
Thanks in advance...
   / John Deere Model 71 drive chain issues #4
Looking at the picture, if you put a straight edge on the driven gear (big one on right side of pic), the chain and drive gear should be in line. The planter in the picture is a 70 Flexi, and doesn't use an idler. In your 71, all the gears have to line up. Another way to check would be to measure from the back of the drive housing to make sure all the gears are at the same distance. HTH. Mark
Kivel 48in Pallet Fork Attackhment (A49251)
Kivel 48in Pallet...
County Line Spreader (A49251)
County Line...
New/Unused 7ft 10 Drawer Stainless Steel Workbench (A48837)
New/Unused 7ft 10...
2015 KENWORTH T800 (INOPERABLE) (A48992)
2015 KENWORTH T800...
Stainless Steel Sprayer (A49251)
Stainless Steel...
Air-Care Decontamination Turbojet (A49251)
Air-Care...
