John deere off set disk
   / John deere off set disk #1
professor
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
Approximately how much hp will it take to pull an 8 foot heavy duty JD off set disk on rocky steep ground?
Can a NH 3930 4WD handle it?
   / John deere off set disk #2
More than a 3930 would want. I would recommend you step down to a 6' disk for your tractor. Think you would wan't something you could pull in 4L or 1H.
You could pull it in most cases but not fast enough. Ideal would be a 75 to 85 hp tractor in a light to medium configuration approximately 7500 lbs.
   / John deere off set disk #3
I agree it might be a bit much for your tractor and terrain. With the steep slopes you may not want such an aggressive tillage tool anyway if you consider the soil erosion factor. Maybe a S-tine cultivator could get the job done without disrupting the soil structure so badly. These are fairly easy to pull and you could pull an 8 footer easily.
   / John deere off set disk #4
Exactly right.
   / John deere off set disk #5
Could you post a pic of the disc? Ken Sweet
   / John deere off set disk #6
Your 3930 tested at ~45 hp (pto) and around 38 hp and 4800 lb pull (drawbar)--similar to my Mahindra 5525. I pull a 7 ft offset disc on flat level ground that has gravely loam soil. Don't know if you can get up enough speed on rocky steep ground.
Is that JD disc a wheel disc (mine isn't)? If so, you can always use the transport wheels to set the disc operating depth to compensate for lack of hp.
My neighbor has an 8 ft offset wheel disc that he pulls with his JD 2640 (~80 hp engine, 6500 lb drawbar pull). He uses it to till his 1/2 acre vegetable garden (mucho overkill but you use what you have).
Good luck.
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
2011 Case 3020 30ft Flex Draper Head WITH TRAILER (A53472)
2011 Case 3020...
Caterpillar 308E2 CR Midi Excavator (A52377)
Caterpillar 308E2...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
