john kba wheel disc
/ john kba wheel disc #1
wanna
orleans county new york state
jd 1070
Hi guys i just bought a 9 foot kba disc at auction for 450 bucks the disc blades look good along with the bearings i plan on using it to finnish my plowed fields any commentes pro or con as to this disc for leveling a plowed lot would be helpfull also an operators manual would be nice p.s. it dose not have a cylender i was thinking about useing a top link to adjust wheels up or down any advice would be great thanks art
/ john kba wheel disc #2
Good disk but your going to need a cylinder.... I don't think those disks are flexible enough to turn on the end of the field without picking it up. The front gang is going to throw up a rut when you try to turn unlike a old drag disk.
/ john kba wheel disc #3
You can get a device called a ratchet jack at TSC that is inexpensive. Hyd. cyl would be best. Ken Sweet
/ john kba wheel disc #4
I have a 13-ft Minneapolis Moline KA-1300 wheel disc ($600, actually made by Krause and rebadged by MM). It has a pretty big hydraulic ram lift the disc. I wouldn't try to turn it without raising it-- the pans would really take a beating if you did that every time you reach the headlands.
Also the ram on my disc is a big sucker--your's probably is also. Probably cost a few hundred $$ new.
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
CATERPILLAR D5K2 LGP CRAWLER DOZER (A64279)
CATERPILLAR D5K2...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
LOT OF PVC & PLASTIC PIPE (A63291)
LOT OF PVC &...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
CADMAN 4500 WIDE BODY HARD HOSE TRAVELER (A63291)
CADMAN 4500 WIDE...
