Just another DIY tractor canopy
   / Just another DIY tractor canopy #21
I was thinking more like the front opening ("windshield") could rack ...it's a parallelogram--a rectangle by design, but no cross bracing ...anyway, doesn't seem to be a problem, but if it should become one, I have a suggestion.
What do you have in mind?
You're correct. It is somewhat of a parallelogram -- actually more of a trapezoid. The base is a little wider than the top, which makes is a little more rack-resistent.
Marcus
   / Just another DIY tractor canopy #23
Here's another cheap idea if you can get a hold of one. Contact your local waste management company to see if they have any old or slightly damaged dumpster lids, or maybe they would even sell you one (like the attached photo). These are already UV protected, obviously waterproof, and fairly light so they are easy to attach to a a tractor's ROPS. front_load_large.jpg
   / Just another DIY tractor canopy #24
Here's another cheap idea if you can get a hold of one. Contact your local waste management company to see if they have any old or slightly damaged dumpster lids, or maybe they would even sell you one (like the attached photo). These are already UV protected, obviously waterproof, and fairly light so they are easy to attach to a a tractor's ROPS. View attachment 429222
Excellent idea. Also add golf cart companies and boneyards if any are nearby. Some of their canopies are narrower in width but make great tractor canopies.
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 KZ Sportsman...
TRAILER AXLE (A54756)
2005 Ford F-650 2,000 Gallon Water Truck (A55788)
2005 Ford F-650...
2001 CATERPILLAR 908 LOADER (A51406)
2001 CATERPILLAR...
Advance SC750 28in Floor Scrubber (A55787)
Advance SC750 28in...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
