Just Changed Hydraulic Fluid in my 2007 MF 1540 - Hydraulics Dead Now
   / Just Changed Hydraulic Fluid in my 2007 MF 1540 - Hydraulics Dead Now
Ok, I will go get the universal fluid and drain the 303 before I put the tractor to work. Thanks.
All the manual says is use "mf permatran iii". It would be nice if Massey Ferguson would spell out what type oil that meant. The cans of 303 say they are "for Massey Ferguson tractors" "where oil of the type is recommended".
   / Just Changed Hydraulic Fluid in my 2007 MF 1540 - Hydraulics Dead Now #13
303 is not a multi viscosity oil. It will not be thin enough at start up to protect your bearings. It is oil developed during the 60's Oil has change so much. Call your local Massey Dealer if you doubt me.
   / Just Changed Hydraulic Fluid in my 2007 MF 1540 - Hydraulics Dead Now #14
I use Tractor Supply universal hydraulic fluid. Fair price and never let me down.
I believe you, your Gold member status make me lean that direction.
   / Just Changed Hydraulic Fluid in my 2007 MF 1540 - Hydraulics Dead Now #16
The air compressor & rag did the trick! Only took a couple of seconds and the 3 point hit popped right up. THANKS!!!
:thumbsup:.....Glad to hear....some hydraulic pumps make lousy vacuum pumps.........when the oil level is below the pump intake sometimes it takes too long to pull oil in......I've used that trick many times on mobile equipment that others fail to prime.
NEW Fork Extensions (A53002)
NEW Fork...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2007 KENWORTH T600 (A52472)
2007 KENWORTH T600...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2023 EXA INDUSTRIAL EXA INDUSTRIAL (A52472)
2023 EXA...
