just 'graduated' to 3/4" tools
   / just 'graduated' to 3/4" tools #11
Re: just \'graduated\' to 3/4\" tools
I agree, Chris. In addition to my half inch impact, I had a 3/8" butterfly and a 3/8" air ratchet. Now if you want a really neat 3/8" ratchet, and don't mind spending a lot of money, find an Ingersoll-Rand IR111 (or the older IR110). They are a "reactionless" or "knucklesaver" ratchet; i.e., both ratchet and impact combined, so they're pretty strong, but won't jerk your hand around when a spinning nut or bolt suddenly gets tight.
Yep.. I've seen hands smashed between air ratchets and objects!
Soundguy
   / just 'graduated' to 3/4" tools #13
I had purchased a Sears Craftsman 3/4" drive set about 10 - 15 years ago to work on my bulldozer. I succeeded in breaking a lot of the Taiwan sockets and complained about the poor quality. They kept replacing them and then one day, I noticed that the sockets were again being made in the USA. I asked if I could swap out all my Taiwan sockets and the department manager said that it was OK with him. The next day, I had a completely new set of Craftsman USA made 3/4" drive sockets. The only socket that I don't have, and have never seen is the 1 9/16". For some reason, I guess that size bolt was never made. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif As many have pointed out many times in the past, it is hard to justify buying Snap On in 3/4" drive because of the cost when the Craftsman will work just as well. By the way, you shouldn't use a 8' long piece of 2" black iron pipe as a ratchet extension. Don't ask how I know... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / just 'graduated' to 3/4" tools #14
I agree with the comments on the sears 3/4" drives. Pricey but worth the money.
I use them on my impact gun, (1/2" drive with an adapter) and they work great for large high torque nuts.
Fred
   / just 'graduated' to 3/4" tools #15
I buy a lot of stuff at Harbor Freight. There's a big HF store in Chico CA about 30 miles from my place. Since I don't use these tools to make a living, I can't justify paying Makita, DeWalt, Porter-Cable prices.
Got one of HD's heavy duty Chinese sawzall ripoffs for $19.99. The motor and drive unit are fine, but the blades aren't worth a hoot. So, off to the local True Value for a pack of Milwaukee blades. Problem solved.
Same for tile saws. I have a $99 Home Depot wet tile saw that's nearly 5 years old. I make tile mosaics so I do a lot of cutting. Chinese motor runs fine and the bearings are solid. Just get a good $50 diamond blade and you can saw tile like a pro. Water slinging is a poor way to lubricate and cool the cutting area. So I rigged a dual-nozzle setup with a few pieces of crimped 1/4-inch copper tubing, plastic hose, a submersible pump from a lawn fountain and a 5-gallon plastic bucket. Works fine and extends blade life like crazy.
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2017 Harley Davidson Electra Glide (A52377)
2017 Harley...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
