Just replaced Clutch, now PTO Wont work. Help!!
   / Just replaced Clutch, now PTO Wont work. Help!!
So I pulled the Shifter, looked everything over and it seems to be in working order. Going to try and split it again and see what's going on.
   / Just replaced Clutch, now PTO Wont work. Help!! #12
um.. if the pto shaft will freespin when engagd to the transmission, you have SERIOUS problems! theck that shifter mechanism over one more time. if it has a splined sliding coupler check that..
The shifter does have a splined coupler and it seems to be working properly. As I move the lever it moves the coupler and engages the pto. I can spin the shaft from the rear of the tractor and I can see it spin where I took the lever cover off. What else do you think might be my issue? The guy I had helping me put the clutch in adjusted the release levers out on the clutch. I am wondering if they are out to far if that might be my problem. I saw no metal shavings or anything that looked as though something was broke or otherwise. My clutch is a 2 stage clutch. After adjustment, an inch or 2 of pedal and the tractor moves. Wouldn't the first stage be the pto. I am thinking something may be wrong with the clutch. Any thoughts would be appreciated.
   / Just replaced Clutch, now PTO Wont work. Help!! #14
even without the trans hooked to the engine. with the pto engaged, and if you spin the shaft, you will have parts in the tranny spinning....
this model I believe has a thrust washer back there.. is the pto really going to complete engagement
? if that thrust washer slips down you can't seat the shaft correctly.
When I spin the PTO I can hear movement all the way up to the case where the input shaft is. I can hear the input shaft spinning.
   / Just replaced Clutch, now PTO Wont work. Help!! #16
8spd? dual clutch?
have you looked at the clutch hub?
Yes 8sp dual clutch. The whole clutch is new. I'm going to split it again and see if there is a problem somewhere. Maybe I should have bought a clutch from ford. I got mine from yesterday tractor.
   / Just replaced Clutch, now PTO Wont work. Help!! #18
i'd look at the hub after pulling it together with the bolts...
My guess is it will be an expensive lesson learned. When you split a tractor, do you pull the steering column? someone told me it's easier to get back together that way.
   / Just replaced Clutch, now PTO Wont work. Help!! #20
depends on what i am doing. i have pulled the steering box and let it hand with a chain froma cherry picker, or i have worked ont hem with the tin already off and just left it on.. all depends on what i am doing.
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
KOMATSU PC150-5 EXCAVATOR (A51246)
KOMATSU PC150-5...
FAE 150/540 LOT NUMBER 137 (A53084)
FAE 150/540 LOT...
