K&N oil filter and air filter ???
   / K&N oil filter and air filter ??? #11
Even if they made one to fit, I wouldn't consider it in the dusty conditions tractors run in. I ran a KN in my Dodge diesel for a several thousand miles and the only difference I noticed was it was louder. After reading of engines being dusted and that Cummins would not warrantee an engine with a KN on it, I switched back to a paper filter. Ever hold a KN up to a light? Pretty obvious why they flow more air.
Kim
   / K&N oil filter and air filter ??? #12
Did you over oil the filter? I only use K&N in my bikes for the last 20 years and work just fine. I know I use Amsoil foam airfilters (back in the day) and silicone where high from over using too much oil.
I now use Amsoil EaA air filters and so far UOA's are fine.
But the Powerchokes (and prior) are not easy on oil.
I don't think so. If I remember correctly, I followed the directions on the clean and re-oil kit.
   / K&N oil filter and air filter ??? #13
Kim
I'm sorry, but the miniscule power gains are not worth the $ for an engine or turbo replacement. Just use what the manufacturer recommends and you will be safe.
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2017 Hino 268 26FT Box Truck (A53422)
2017 Hino 268 26FT...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A55218)
2019 BOBCAT T630...
2012 Cadillac CTS Sedan (A53424)
2012 Cadillac CTS...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A54607)
2006 KENWORTH T800...
