aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 16,985
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
You can have a gear type shuttle shift, it let's you choose the gear from the shifter on the floor and fwd/reverse from the shuttle on the console.The major hint here is he says it is in post #3 "It's an automatic shuttle type of trans".
With having a shuttle shift with wet clutches it will require UDT if not Super UDT or UDT2. Already saying it is sluggish, will probably get worse with ATF.
No need to question here, just sit back and get popcorn while the clutches rip apart.
David
You have to press the clutch pedal to change gears or directions.
I grew up with a Massey Industrial 35 that was setup that way.
Aaron Z
