3-Point Hitch Kama 554 TPH Arms Stuck Up
   / Kama 554 TPH Arms Stuck Up
Went to that forum and it has a boat load of info! Thank you! Hope I can figure it out now.
   / Kama 554 TPH Arms Stuck Up #12
Is it possible for the arms to go too high and get past center or something?
Anything's possible I guess, if perhaps the internal stop broke off or some such thing. All I can say is that I've got a combined 10+ years and over 800 hours on my two. No lift problems. So I can't attest personally to any issues with lifting them too high
//greg//
//greg//
I'm going to do some further investigation today, start by looking into the hyd. valve assy. Thanks for the input. I'll post my findings.
   / Kama 554 TPH Arms Stuck Up #14
I can only speak of my kama ts354c (2004). The lift box has a lever on the rear left corner that will lock the lift in the raised position. I moved this lever accidentally one time and spent a lot of time trying to find the problem. Check it out. You may be lucky.
kidney
   / Kama 554 TPH Arms Stuck Up #15
kidney
I have a TS354C and a KM454 (the 3 cylinder version of the OP's 4 cylinder KM554). The 354 and 454/554 are completely different tractors.
That lever on yours is the PTO engage/disengage. The hydraulics are run by a PTO pump. If/when you accidentally disengage the 354 PTO, you disable your hydraulics completely (except steering). The 454/554 has no such lever. The recommended solution to your lever problem is a hacksaw. Cut the lever down so there's only about 4 inches remaining, then leave it permanently in the engaged position.
//greg//
   / Kama 554 TPH Arms Stuck Up #16
apples and oranges greg. Please understand I know of the lever you are referring too. But I am referring to a different lever. As I stated it locked the lift in the raised position. I know what I am talking about on this matter. You need to be open to new ideas from people who have some knowlodge of their tractors. I do not like to be told I don't know what I am talking about. Have a great day
kidney
   / Kama 554 TPH Arms Stuck Up #17
kidney
you need to post a pic of this lever
   / Kama 554 TPH Arms Stuck Up #18
That door swings both ways sir. What you're apparently talking about is the TS354C hydraulic diverter valve. When hydraulic fluid is needed on the single remote, that valve diverts fluid from the lift to the remote (pressurized output, gravity return). When the valve is turned to divert fluid to the remote, the rear lift is disabled. Either/or. Ordinarily that valve is controlled by a a simple hex head bolt sticking out of the sump (above the external filter housing). So someone must have tack-welded a handle on yours.
Understand also that - even though our TS354Cs are made by KAMA - they're in the CUT category. The KM454/554 is up in the UT category. As such they're equipped with two sets of hydraulic remotes with associated flow control valves under the left floorboard (pressurized both ways). As such, we're dealing here with a completely different tractor configuration than yours. So thanks for the input, but it's wholly inapplicable to this particular KM554 topic.
//greg//
   / Kama 554 TPH Arms Stuck Up #19
once again greg you are wrong. please refer to your kama ts series parts catalogue. mine is a 2004 model ts354c. on page #97 is the lifter assembly. the part #24 is named lock shaft sub-assembly. this is the lever I am referring to. in my tractor operation manual on page #34 it shows the lifter assembly. part # 3 of figure 3-13 is the lock shaft. the lever is on this shaft. i hope this helps to clear this up. now my lift box may be different then yours but as I stated this is what will hold my lift in the raised position. I was offering information that may be helpful. if it was unclear sorry but do not assume you know what I am talking about. I was trying to help not get in a debate. this is why I chose not to post must of the time.
kidney
   / Kama 554 TPH Arms Stuck Up #20
Hmmm, that "lockshaft" was apparently either problematic or redundant. Because it's not on any of the 2005/2006 models I've seen. Matter of fact, there's not even a hole in the sump at that spot. But continuing to beat this very dead horse is only prolonging the agony. I'm surprised you didn't figure out that figure 3-13 is mislabeled. Item 3 is the drain plug. The "lockshaft" - on those tractors so equipped - is on the other side of the lift box. A quick look at your own tractor should quickly confirm this.
Nonetheless, you persist in ignoring the BIG point. Despite the fact that this topic involves a KAMA brand tractor, not all KAMA are made the same. We already found that out with your "lockshaft". So again: the KM454/554 tractors have an entirely different hydraulic configuration than does your TS354C - to include the fact that there's no "lockshaft".
//greg//
7061 (A53421)
7061 (A53421)
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
