Buying Advice KAMA advice, KM 454 & TS 354C
   / KAMA advice, KM 454 & TS 354C #21
</font><font color="blue" class="small">( I was told there maybe some kind of switch that after the tractor starts it would put the system in parallel. This switch maybe be built in now but we don't know. )</font>
Yes. It's called a direct/parallel switch, common on diesel powered vehicles/planes/boats that require some extra ooomph to start, but then fall back to conventional 12v for lighting/accessories and charging. One position on the switch cuts out all 12v devices, and throws 24v at the starter. Once running, the switch is returned to the 12v position. The reason I asked about thermal start assist devices, is that some ignition switches keep them energized while the starter motor is turning over the engine.
The other thing a good series/parallel switch has to do is charge both batteries. So there has to be some "phantom" wiring involved to return charging voltage to the 2nd battery - even though it's not actually "online". A 1000 amp series/parallel switch for your application would run about $140 bucks, plus labor and materials to install. And you're also faced with fabricating some accommodation for second 12v battery.
That said, I still think you'd be better in the long run to force the issue of getting a 12v starter and solenoid under warranty. My KM454 is direct injection as well, but with the more typical one (12v) battery starting/charging system. Coldest morning here so far this winter has been 16F, and it's not failed to start yet. But use of the compression release is absolutely mandatory.
As far an existing series/parallel switch, I doubt it. There IS a KAMA variation that employs two batteries. But KAMA parts book illustrates the two-battery system as employing two SIX volt batteries - still making it a 12V tractor. This is seemingly confirmed by the fact that both the single and dual battery variants list the same replacement voltage regulator.
One final question: are you actually convinced you have a 24v starter motor? The parts manual fails to list a KAMA part number for the thing, suggesting that it's a vendor item - possibly a mismarked vendor item(?) The label on my starter motor housing contains mostly Asian characters, but I can make out that it's a 2.5KW Wudian QD1315 starter. The solenoid is unmarked.
Hope that helps.
//greg//
   / KAMA advice, KM 454 & TS 354C #22
Just checked a new starter and it is clearly marked (well in small stamping) 12 Volts. If yours is marked 24volts than that is the problem. Also, I hope you don't have the Chinese n the engine. It gets thick as straight STP at cold temps, really slows down the starting.
   / KAMA advice, KM 454 & TS 354C #23
Thank you so much for sharing your knowledge. It sounds like the best option is asking for a 12 volt starter. The one that came with the tractor is marked clearly with a 24V and chinese characters. When the tractor is kept warm in the garage the 12 volt battery will start the tractor. It makes clicking noice at the cellinoid that I have heard on a car with a weak battery. I think it is truely a 24 volt starter. Having that extra crancking power is attractive but might not be wearth the trouble. thank you again
   / KAMA advice, KM 454 & TS 354C #24
</font><font color="blue" class="small">( Also, I hope you don't have the Chinese n the engine. It gets thick as straight STP at cold temps, really slows down the starting.
)</font>
You think if he had a chinese in his engine you would here him screaming when you cranked it over /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif
Sorry Chip, couldnt resist
   / KAMA advice, KM 454 & TS 354C #25
LOL! I was supposed to say Chinese oil....guess there isn't any in there....
   / KAMA advice, KM 454 & TS 354C #26
In regard to dealers in Southern Indiana,
North of Spencer, across from the old Drive-in theater is a 'distributor'. I don't have into on him handy -- I used to have a buisness card somehwere.
The closest thing to a real dealer that I've found is in Linton, IN. Hamilton, Equipment. I stopped in one night back in October and had a long talk about repairs, parts, performance, etc... Yahoo shows his number as:
(812)847-2805
   / KAMA advice, KM 454 & TS 354C #27
Paddy,
I just reread this thread and see I never responded to your question. So Sorry!. We can arrange delivery to Indiana. We have 4 KM454 still available from the shipment that is on the water now. send me a PM if you want to reserve one, I will give you a great delivered price! Happy New Year.
T/A Utility Trailer (A56858)
T/A Utility...
UNUSED FUTURE FT-P45 HYD BREAKER HAMMER (A58376)
UNUSED FUTURE...
72" Tiller (A57148)
72" Tiller (A57148)
1983 Ford 8000 Tandem Grain Truck (A59814)
1983 Ford 8000...
Club Car XRT 1200 Golf Cart (A57149)
Club Car XRT 1200...
6.25 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
6.25 In Heavy Duty...
