Kawasaki Mule 2510
   / Kawasaki Mule 2510 #1
yanmars
Platinum Member
I have water getting into the oil. Trying to find out from the prior owner if it ever got hot. Will be checking for head warpage. It was apart because a valve stuck and bent a push rod. That is corrected and then the leakage was discovered. It is an aftermarket head gasket.
Anyone have anything similar or ideas. Thanks
   / Kawasaki Mule 2510 #2
While the head is off, look for cracks too. If it's an iron head, best to get it Magnafluxed...it aluminum, use a dye penetrant.
I will have it checked.
