Keep Hydraulic System @ Rated RPM
   / Keep Hydraulic System @ Rated RPM
The KAMA 554 has 2 pumps...one separate for the power steering. That is really the one I'm interested in reving up. Under normal loader use when transporting dirt in the bucket, I cruise to the spot for dumping and sometimes the power steering does not react unless I crank up the rpm's.
My question was to see if
1) it is possible to change to a higher flow?
2) if there is something out there already?
3) keep it simple?
4) or not worth it?..just increase the rpm's? (obvious solution, ha ha)
Thanks,
3) keep it simple?
Thanks,
   / Keep Hydraulic System @ Rated RPM #13
I'd look for a higher capacity pump... the excess oil is just dumped anyway..
Soundguy
   / Keep Hydraulic System @ Rated RPM #14
Soundguy
   / Keep Hydraulic System @ Rated RPM #15
it's mostly the way things are, unless you wanna spend gobs of money, on a system that's gonna take alot of room, alot of plumbing, and may have some odd quirks. some excivators and new equipment have varriable displacement pumps, and presure compensated systems, but they are $$$ equipment, and built for a guy who's running them 10-12 hours a day.
our 580 case, although an older machine has the same thing. if you want more power to steer, or faster loader travel, you shove in the clutch, and rev it up.
if its your steering. have you tried putting some weight on the 3pt hitch when doin loader work? it'll take some of the load off the front, and allow it to steer easier.
   / Keep Hydraulic System @ Rated RPM #16
That's where hydrostatic transmissions really shine. The ground speed is independant of engine speed (except for maximum speed of course).
   / Keep Hydraulic System @ Rated RPM #17
However.. PTO speed is still ratio-locked with the engine speed...
Soundguy
   / Keep Hydraulic System @ Rated RPM #18
I would look into changing JUST the pully on the pump.
Surely you can find one to fit or make one fit.
You'll need to go smaller, just a little smaller than stock.
Gene
Gene
Well,
I looked in the parts manual and it appears that my pump(s) are gear driven. But you have given me an idea. Now I'll need to check if spinning the OEM pump faster will hurt it?
Thanks,
   / Keep Hydraulic System @ Rated RPM #20
3RRL said:
Well,
Thanks,
Thats what i would be conserned with. If it spins close to "normal" speed after you modifiy it at only 1500 (engine) rpm then it might over rev and cavatate at higher engine rpm.
JOHN DEERE F725 LOT NUMBER 101 (A53084)
JOHN DEERE F725...
2019 KOMATSU WA320-8 WHEEL LOADER (A51246)
2019 KOMATSU...
UNUSED FUTURE FT-XJ7T 7 TON 46" HYD THUMB CLAMP (A51248)
UNUSED FUTURE...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
Ryobi Sliding Miter Saw (A51573)
Ryobi Sliding...
Spartan Pierce Foam Pumper Training Fire Truck (A51692)
Spartan Pierce...
