Keeping Water Tank Cool??
   / Keeping Water Tank Cool?? #11
seeing you are in texas. you should be able to do a DIY evaporator cooler / swamp cooler.
run say 1/2" pex around the water tank. as if winding up string on a spindle. (one layer thick) then run ends to a evaporator cooler outside.
no direct experience with DIY evaporator coolers for actual cooling.
was thinking along the lines of instead of running one of them small "mini fridges" and tossing a roll of pex in it. but with you being in texas. i would imagine an evaporator cooler would be much better / cheaper design long term to chill the water.
   / Keeping Water Tank Cool?? #12
How much water are you drinking that you can't keep a jug in the fridge? You could also run a line thru a small dorm style fridge and then the line out to the tap.
   / Keeping Water Tank Cool?? #13
I am just curious. My pressure tank has the water line from the well attached to the bottom of the tank with a T. The water line exits the T and goes to the house for drinking and the water softener.
There is not really any water or not much anyway that gets run through the pressure tank. If that is the case with yours, insulation might not help anything. Insulating the water lines would. That said, insulating the tank wouldn't hurt anything either.
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Harrell 3605 (A50123)
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
