Keeps Blowing fuse
   / Keeps Blowing fuse #11
Lose connection was your problem. Lose connection increases circuit resistance. But I'd double check for frey on that wire.
Fixed the lose connection and seems to solved the problem. Now new problem. Backhoe is leaking down. Let it sit for around 8 hours and it had leaked downed almost to the ground. Where to start the search?
   / Keeps Blowing fuse #13
8 hours sounds about right for allowed rate of drift. Any specs in the manual?:confused3:
Couldnt find anything in the manual. But The tractor has sat for up to a month over the last year, and has not leaked down that much.
   / Keeps Blowing fuse #15
I don't know of any backhoes that wont leak down at least a bit overnight. Most will hit the ground especially after having a few hours of operating time on them. My B26 TLB if left unpinned will leak down about halfway in 12 hours and to the ground in 24. Stabs, bucket and thumb also leak down with time. Maybe not an acceptable situation but it is an accepted response from the valves on TLB's.
   / Keeps Blowing fuse #16
8 hours? and that's a problem?
if it was 8 minutes it might not even be a problem for 99% of jobs.
If you are looking for problems to solve that won't make much impact int he real world.. you can send 19$ a month to one of those places on tv that says they fix the life for hungry kids in ira-frica-istan.
   / Keeps Blowing fuse #17
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
2013 PHOENIX GLOBAL TANDEM AXLE MANIFOLD TRAILER (A52472)
2013 PHOENIX...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
ASSET DESCRIPTIONS & CONDITION (A52577)
ASSET DESCRIPTIONS...
