Kerosene instead of Lead Substitute
   / Kerosene instead of Lead Substitute #11
Most ford ( 9n-2n-8n) left the factory with hard valves seats... ( the war time models may not have had hardened intake seats.. but that was just right around 42.. from there and on you should be good to go..).
And i wouldn't worry about putting anything in the gas as a lubricator... Like 'lead substitue'.. you are just lining the pockets of the retail outlets. I know some people add diesel to prevent spark knock ( preignition).. and that was what tetraethyl lead was really for anyway.. octane modifier... fords were using lo 70's octan gas and did fine.. lowest you can find nowadays this side of the border is about 87.. so you are good to go.
I fyou feel like you have to add something to the gas.. drop in a couple ounces of marvel myster oil per tank ( won't do much ).
Soundguy
Soundguy
   / Kerosene instead of Lead Substitute #12
Again, thanks for the definitive answer, Soundguy.
mark
   / Kerosene instead of Lead Substitute #13
mark
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
E-Z Trail 700 bu Auger Wagon (A59814)
E-Z Trail 700 bu...
2006 Tusk 500 PG-16 Forklift  3-Stage 188in Lift with Aux Hydraulics (A56436)
2006 Tusk 500...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
